Perfect!
Thanks Gerry!
I had a chance to dis assemble that 57 xfmr, there is some Son of Flubber glue in there that loosens up real nice with a little heat:
http://vacuumbrain.com/The_Lab/TA/Microphone/SM57/57_1.jpg
If you are having problems getting the XLR out, this might help.
That screw gets Un screwed to secure the jack. So that means to remove the jack, you screw it in depper, not loosen it. When you uncsrew it, it rises into a keeper hole in the body.
Check the cheap-azz ground method used here:
http://vacuumbrain.com/The_Lab/TA/Microphone/SM57/57_3.jpg
With the xlr wires cut, the xfmr can come out the top.
Here comes the flubber:
There's all my leakage! Right where I expected it.
See the red outer secondary?
See how far it is from the core?
Bad news. No coupling. Thats where the 4 mH leakage comes from.
The pri (red inner winding) leakage is not that bad because the winding is closer to the core.
This is noplace for a bobbin wound transformer.This application really needs a layerd paper approach. This gets the wires right on the core.
A very delicate signal (unless miking Def Tones Ampeg cabs)
needs an efficient transformer. This is the first transformer that had a varying tuns ratio based on level, so I knew it was going to be a piece.
Voltage ratio went up with level due to low linkage factors.
