Over-voltage on tube heater… any damage?
elskardio
Montreal - Canada
Hi guys,
While testing a 6s6b tube, my psu regulator for the heater died and the tube filament received 12v for 1-2 minutes instead of 6v.
Can this damage the tube?
Heater volts are specified +/- a % in tube service docs ,factory heater burn in might already encompass an over voltage by a considerable margin ,over a short period of time ,
If on test (presumably with the tube mic circuit you envisage) the tube performs satisfactorily ,treat it as good .
The tube still works in the microphone (m49 style) but I have a feeling there’s less bass frequencies than before the incident… I have an other 6s6b on the bench. I will swap them to double check
