Svart
yeah you should NOT get DC on the output. The transformer IS the isolation. If you get DC then something is not hooked up right with your output transformer.
Matthew Jacobs said:Svart, in PRR original design the output comes directly out of a 5532 op-amp. I checked the 5532 schematic, it appears that it could output DC from it's power rails. I'm not sure because of my limited knowledge of electronics. Most designs I've seen either have a transformer or DC blocking caps after an op-amp.
Just wondering if this compressor needs blocking caps? Or if it's normal to have DC coming out of a op-amp?
Matthew Jacobs said:[...]About -9.43V, is this normal?
jdbakker said:A few tens of mV is not abnormal for many op-amps in sane configurations; sometimes more (100-200mV), especially in higher gain configurations. Many semiconductor inputs don't care, but switching signals with a DC offset can cause clicks and transformers can get saturated and/or magnetized. In those cases a coupling cap or a servo is in order.
Totally agree... 90% of the time operator error.jdbakker said:[safe money always says operator error, no matter whether you, I or anyone else here has built it.]
