> the AC701K is highly photosensitive
It (and most tubes) are slightly photosensitive; worse in this application because (as you say) grid current matters.
The photo-problem was only noticed when photographers used flash-bulbs close to the mike. If you build a very good mike, and put it front of Famous People, that happens. But most of us are not worth photographing.
> the 5784WB has a grid curent of 300,000 pA
That's Maximum, not typical. 90+% of 5784 will have much-much lower Ig; at $5/each, we can afford to sort-out the worst leakers, and hand-trim the remaining bias-error.
Will it be as-excellent-as AC701? No. Will it work? Yes, and perhaps quite well. It gives a $50-$500 mike instead of a $500-$5,000 mike. For many of us, that's just our level.
