Shea,
For implementing a tube stage in the GSSL, I'd definitely recommend to build them as two separate units, one GSSL as-is, and one separate GPultec amplifier board. Not only much easier in terms of power supply, but also much more versatile in the long run (the amplifier could e.g. be used as a linedriver or even a low-gain micpre given the right input transformer)
For using the GPultec stage as current-to-voltage conversion for VCA output, you could experiment with using feedback (e.g. 15K Ohm) from SRPP's output to input (outside DC-blocking capacitors), and pouring in the current from the VCA through another 15K resistor (omitting the output opamps in the GSSL). I'm not entirely sure how it would turn out specs-wise, but it should work someway or another.
Jakob E.
