hitchhiker,
which thread was that, about the pads?
axismatt,
great it worked. so you do get a good sount with 2 x 40 ohms? have you tried something like 2 x 600 (to get Z.in of 1K2, which is common in mic pre's); comparison sound-wise? - got to check that myself sometime, would be interesting.
about phantom pwr, you would either need a dc to dc converter to get to +48v properly, or build a dedicated supply. the latter is fairly easy actually.
there are some professional designs (if not top of the line) around which simply use +24v for phantom powering, though. some mic's might not like it, and probably you'll get a degradation in max. spl (maybe in overall sound, even), but if you wanna try for simplicity, you could apply +24v into the mic lines via two matched (>0.4%) 3k4 resistors, and see if you're happy with the result. for that, a little pre-filtering of the supply with, say, 200 R in series and a 220uF cap to ground wouldn't hurt, either.
different suggestions, anyone?
axismatt,
