Svart
Oh i can't wait to give them a try!
I feel adressed! :green:For the picky ones you know...
Looking at circuits like this, I see most using the gainpot just as you describe them, but I may be getting things wrong.It is based on the JLM boards and uses two BigBloaks for gain and the signal chain is LL1538XL+BigBloak+BigBloak+CMOB-2H.
When you use the JLM board do not hook up the gain potentiometer as shown on his drawings. His is wired so that as you increase gain the value of feedback resistor increases. This is bad for a current feedback amp as you limit the bandwidth as you increase gain, just the opposite what you want. I recommend that you wire the pot in a more traditional fashion as shown on the document packet posted earlier. I used a 10k dual rlog also from JLM.
Thanks for the info, that'll broaden the options. I understand that for a dual section-pre I'd actually only need one BigBloak, or did you use two anyway for that lower THD ?I think any of the BD677/678, BD679/680, BD681/682 pairs would work if you can find them.
Right, why go out & pay an Euro for a 10% or 20% JFET-part (sloppy for some reference-ish thing) when you can stay inside & test a few JFETs yourself :wink:I used a KSK30 (2SK30 equivalent) that works for the current regulator just connecting the gate to source. There are many JFETs that have Idss ratings around a milliamp.
Yes. [/quote][quote author="clintrubber"]You're using the dual gain-pot (one section for each opamp) as well ?
Both of them were BigBloaks. The new owner likes his sound squeeeeeeeeeeeky clean. This is a guy who gets his ear canals flushed every few months to keep his high frequency hearing in top shape.[/quote][quote author="clintrubber"]I understand that for a dual section-pre I'd actually only need one BigBloak, or did you use two anyway for that lower THD ?
