Hey guys,
I'm wondering if there's a good way to measure the amount of usable gain I'm getting from my 312 clones.
I find that when I record bass through a DI (Radial JDI - passive), I have to crank the gain on the 312 right up to even get a useable signal from the live level output.
Any ideas?
Scott
Bump
What do you mean by usable?
The JDI will attenuate (step down TX) as well as change the impedance of your signal. Depending on the type of pickups on your bass (passive or active) and their driving capabilities (output impedance), you will find that the signal out of the JDI is very low (in the case of a passive, high impedance pickup) or fairly hot (in the case of an active pickup with booster/preamp circuit).
It's hard to tell without knowing more.
You can easily get 70dB of gain out of a 312 pre if you use the correct components.
Mike
