Yes, you will want a Zobel after the EA2622. I use a 10K R and a 220pF C. It's not what my original input channel skiz or the old 312 skiz show, but it is what is most commonly found on the PCB's themselves. Ed has confirmed this. You will be happy with the results.sethmopod said:...2) As stated earlier, my input transformer is an EA2622. I noted on your schematic that there is a Zobel network available for the transformer secondary, but your BOM has R5 & C1 blanked out. I read in this post - http://www.groupdiy.com/index.php?action=printpage;topic=34515.0 14th reply - that the EA2622 should have the Zobel. Do you have any thoughts on this?
Do I need to ground the XLR jacks?
Hi Marten,martthie_08 said:...I would like to ask a question as well, not knowing if this has been discussed here before: I am currently building a 312 style circuit based on Mitsos boards and it has provision for a DC coupling cap between the opamp output and the output transformer.
On my past 312 style builds I have omitted this cap, like on the original API schematic. So is it a matter of how much DC is "on" the audio signal and how much DC the specific output transformer can "take" or is it generally considered not good circuit design to omit the coupling cap?
I was expecting a large shipment before Christmas. They are late which has been the norm. Ed tells me now that I will get them just after the 1st of the year.edit: Jeff if you read this, any idea when you will get the EA 2623-1 output transformer back in stock? Or do you happen to have a pair left over somewhere, can be used, don't matter...
