JohnRoberts said:I am starting to suspect there are more than values different about the schematic I am looking at...
If R11 and R12 are the 1k input resistors (R12 and R13 on my schematic), you can drop them some, but will run into diminishing returns quickly, and dropping that value too low will load down the microphone output at some point. I wouldn't advise much below 750 ohms to maintain a bridging termination to 150 ohm source impedance.
The R6 I mentioned is in the wiper of the mic input level pot, and should not interact with the link input gain (at least on the schematic I am looking at.) If R6 is feeding an inverting input to the output opamp, only it's gain will be changed (increased) by dropping the resistance value.
wow, I can't believe I missed that.. of course each feed to the mix bus has it's own gain ratio with the output driver.
so the only hit would be increased noise. I'll have to try it out and see..
thanks.
Jason
