fragchamp said:I have this exact problem with LM4562, dual rails and 1M bias resistors. It latches to the negative rail and seems to destroy the opamp if left for any length of time. This is something that should be on the datasheet.
Surely there's a better way.. I would change the chip before resorting to relaysfragchamp said:+-17V rails, and it doesn't latch every time, which caused me to miss the problem at the design stage. I've had it occur with single supply operation also, where it latches to ground. Diodes or low value resistors are NA in my case, so I'm going to try using relays to short the inputs on startup.
