strangeandbouncy
dear All,
I've just completed my first 2520 RC v1. it works beautifully in my home-brew API 553-based passive-eq (with switchable frequencies). I haven't tried it in a high gain application, 'cos i don't have one - Yet!
Let me give you the values I used.
Q1/2 - hfe 530 matched
Q3/4 - hfe 460 matched
R1 - 150k
R2 - 100R
R3 - 82k
R4+R5 - 82k('cos I can't add up! Should be 90k . . . )
R6 - 3k9
R7 - 3k3
R8/14/15 - 1k
R9/13 - 56R
R10 - 800R
R11/12 - 5R6
R16 - 47k
C1 - 1000pF
C2/3 - 47pF
C4 - 39pF
C5 - 10pF
D1 - 2xIN4148
D2/3 - IN4148
All caps ceramic, All resistors - 1/8th Watt, except R11/12 - 1/2 Watt.
Next one finished tonight, testing tomorrow - must have STEREO Eq's after all ! . . . I have 6 positions in the HF - I guess@10kHz-22kHz-ish. I am waiting to order Inductors from Sowter, but no money at the 'mo . . . I changed feedback cap around 2520 from 180pF to 150pF - again, by mistake! When I corrected them to 180pF the eq sounded "smeary" especially on the upper settings, so i put 150pF bach again. Much sweeter than my original API 553. Maybe it needs re-capping(?) It has a "Melville" 2520. When I dropped my new 2520 in on the old unit, it sounded remarkably similar, definately API, but a tad more detail in the top end. I also noticed a distinct difference between using polystyrene caps and polyester in the passive eq. Never really noticed this phenomenon before. Polystyrene is much "richer" sounding. Polyester still sounds fantastic, tho'. Can't wait to build second unit and try phase reversing one with polyester to see what the difference is . . .
Gawd Blimey! This is so much FUN!!!!!!!
- Fabio, You are the greatest! This IS the eq I have always wanted - SO SWEET! - and i have only made the HF part so far! I want to try 3 frequencies in the LF(Shelf) and no mid-range.
ps - BTW, should I change feedback cap on Melcor to 10pF too?
:guinness: :sam: :guinness: :green: :grin: :green:
Andy-"Loadsa-Sweet-Top-End-Now!"-P
R1 - 150k
R2 - 100R
R3 - 82k
R6 - 3k9
R7 - 3k3
R8/14/15 - 1k
R9/13 - 56R
R10 - 800R
R11/12 - 5R6
R16 - 47k
C1 - 1000pF
C2/3 - 47pF
C4 - 39pF
C5 - 10pF
D1 - 2xIN4148
D2/3 - IN4148
