[quote author="Bauman"]Hey,
Yes, 2 diodes as D1. No you should solder R14+C3 and then solder each side to the board. R4+R5 must be like 20k or 22k, and make R3 the same.
With 82k as shown it doesn´t work welll...
[/quote]
D1=OK, r15+c3(I solder them in series and then connect one leg from r14 and one from c3? Is it the same procedure with c2+r10?) ,r4+r5 (is there an updated partlist or where do I find the changes? I found some here but I´ve missed the 20-22k stuff,maybe I´ve missed more....
Thanks/Balluda
Hi All .I´m building my first 2520 opamp and have some questions:
Should I connect two diodes in series on D1 ? Do I solder r15 and c3 together on the upper side ? Should I use two resistors on r4+r5 to sum the value (90k)or should I use one resistor ? I´m using Fabios 2520BCr.1
[/quote]
Thanks/Balluda
