strangeandbouncy
Anyhow . . . .
moving rapidly on . . . .
I am following this thread with mucho interest....
Boys get to it...
omeiko wrote:
After listening some music through them I found out that the melcor, and the two apis sound quite similar. Melcor is a little softer and the 2520BC has a little more bass than the 2520r268 in a quick listening test.
The AM 10 is my favorite in a line op application. It has a great character but it's quite clean at the same time.
The JE990 and mr Forssel's jfet are both very clean but slightly different from each other.
These tests were nothing too serious, just the first impressions so don't make any conclusions based on this.
Now I have to make mic pre cards to make some more testing. I'll post more impressions after I'm done. Is anyone interested in sound clips? I could make some during the tests.
Cheers!
Did you ended up testing this babies a little more? Wink
..if it is not twice R1, then the Ics are unbalanced and there is a wholly avoidable rise in 3rd-harmonic THD at high frequencies....
I've finished two melcors last night... and i got the "problem" you're talking about... a peaking @ +- 1MHz at lower gains using condenser mics... i tried different feedback caps, but no way to solve it... have you any suggestion/solution to solve this issue ?
By tail resistor you mean R1 (130K) ??
Hi All .I´m building my first 2520 opamp and have some questions:
Should I connect two diodes in series on D1 ? Do I solder r15 and c3 together on the upper side ? Should I use two resistors on r4+r5 to sum the value (90k)or should I use one resistor ? I´m using Fabios 2520BCr.1
