Would love to see the inside anyway.
mitsos said:You may have the pot wired backwards... check back a few pages for a visual.
actually, just checked, it's here(gltech's post)
http://www.groupdiy.com/index.php?topic=28684.20
kato said:How did you fit 2 channels in there? Got any internal pics?
Whoops said:The Toroidal transf is quite close to the PCB , are they quiet?
Don't you have any induced Hum?
PRR said:The supply current for this preamp is under 40mA per channel. 8 channels would be 300mA. I do not see this PS schematic, but assuming it is conventional you should use a 600mA to 1A transformer, and fairly good size heatsinks on the regulators, like 2 inches 5cM square.
PRR said:> how much "better" they are in the circuit than the tl07xs?
According to Doug's page: {052} Offset voltage is 0.65 mV typ, 1.5 mV max, compared with the TL072's 3mV typ, 10mV max. It has half the bias current of the TL072.
Very significantly better DC error correction. The 07x will work, but the 052 much better.
The drain of the 052 is so small I would just use 15V Zeners with say 1K resistors for one channel, 150 ohm resistors for a +/-15V supply for 8 channels.
Yup ,should be ok, 50va is fine for 4 ,as well as led meter and phantom powerkato said:I have an unused 10VA toroid sitting around.
Would this provide enough current for 1 channel, including balancer board?
